Black LED Halo Projector Head Lights
Should I try t exchange for another set or it's a waste of time. There're only two people I know having passenger side adjustment issue, 2 for 2 means it is a problem with the mold. But, deep inside I want give another try with another set? What do you think?
These are cheap made headlights man, you will pay what you get for, there is a reason why they are so affordable. If you want to have professional grade projectors, you might want to look into retrofitting them yourself instead, not too many choices for our 4th gen out there when it comes to projector headlights.
I connected my 3 led's so that they are always on while driving, but they alternate (off/on) with the turn signal. When the TS is on the led's are off on that side. I noticed an Audi that did this and thought it would be a nice effect. And I do like it.
It was an easy and inexpensive mod, I purchased the relays on Amazon for about $8 plus some wire and heat shrink. I did add a flat trailer connector to make the install a little cleaner.
Could you post a wiring diagram or explain how you made so the TS cuts of the LED's?
One last thing, here is a link for a guide in making your own retrofit. I'm planning on doing this eventually as a hobby, just need to find a set of cheap h/l assembly and save some dough for the projectors.
TRS Tech: Installing the Morimoto Retro-Quik System for Spyder Spec D Halo Projector Headlights - YouTube
I have an 03 Limited Black that looks just like this, but I went with the Spec D HID Silver. Need to install them and I hope they tie in the Silver bumper "inset".
But your Black set look good! Making me second guess my choice.
Update: Garage pics have been updated with new headlights.
Need to post a pic with the light pattern on the wall for ya.
Not to hijack the thread but with Lrc1123 permission, I'll just continue with this one instead of starting a whole new one.
I'm about to pull the trigger and purchase these Minis from theretrofitsource:
Bi-xenon Morimoto Mini Stage III Kit (H1)
Any concerns or thought before I make the purchase? I will be retrofitting my blacked out Depo headlights which I can't stand it's current performance, the reflection is garbage.
I think they are worth it. If I don't plan to sale mine I would have looked into something like that.
Good luck and please don't forget to report back with pics!!
seltzernator
