2001 4-Runner
Good thread -- I made a similar pressure bleeder using a 1.5"x1.25" Fernco flexible fitting, 1.25" x 3/4" PVC bushing with thread, 3/4" blk iron thd'd nipple, 3/4" x 1/4" blk iron reducing thd'd elbow, and 1/4" x 3/8" reducing bushing for the air fitting. This is just what was available at Ace Hardware to make it happen. Just had to cut off the thick end portion of the Fernco flexible fitting to make it clamp down to the brake fluid reservoir.
(1) With key off, pressed on the brakes for 40+ times until de-pressurized.
(2) Poured new brake fluid in reservoir to top off (just over Max).
(3) Installed pressure bleeder on the reservoir. Made sure it had snug fit.
(4) Applied about 5-10 psi max. Only enough to do the job.
(5) Starting on passenger rear, began bleeding.
(6) Checking pressure between wheels to keep around 5 psi, worked from Driver Rear, Pass. Frt, Driver Frt.
(7) Removed pressure gear, and screwed on reservoir cap.
(8) With key on, let the pump build up pressure again (about 30 sec) and shut off.
(9) With key on, press brake pedal 20+ times until pump comes back on (beeping sound).
(10) Re-filled brake reservoir.
(11) Repeated steps 9 & 10 once more.
All done. The brakes have been fine ever since. Not the same easy program with other cars, so thought it would be good to post this procedure.
