block heater
typack
Banned
i need to install a block heater in my 03 limited with the v8. is this an easy install? has anyone done this?
thanks in advance.
thanks in advance.
Are your rear door functions restored?
Check with toyota to see if they offer one for the v8. The block heater they offer for the v6 took me about 15 min. to install. That block heater fits just about all their cars but I can't recall if it fits your v8.
Re: Re: block heater
I did what you suggested and had some success. The defrost button will now light up and I can hear the washer fluid motor working but now the window will not go down. I disconnected the neg off the battery for about 20 min and when I reconnected the problem came back exactly as when we started. I could roll down the window but nothing else would work. I rolled the window down from the dash button and then all the way back up holding the button down at the top for about ten sec. The defrost, wiper and sprayer worked but the window would not work anymore? Any suggestions? Anyone?
Thanks again.
Hey typack,
When I purchased my 03 T4R Limited V8 I had my local Toyota dealer install a block heater - a must have for our cold Canadian winters.
Bossman said:
Hey typack,
if you do not mind, do you recall how much it set you back?
thanks
Re: Re: Re: block heater
Thanks again.
On the drivers door controls make sure the window lock button is not depressed.
Re: Re: Re: Re: block heater
i will try that tommorrow but i am pretty the lockout is not depressed. thank you for the help and i will let you know i make out.
has anyone out there installed a block heater in an 03 4runner v8? if so where did you get the part and how was the install?
thanks
thanks
thanks
thanks
thanks
Try posting this in the main forum...
thanks
Typack, when I bought my T4R used (had it brought up here from southern Ontario) my local Toyota dealer put the block heater in for me at no charge - I've built a good relationship with them over many, many years and they look after me that way ;)
