Blower Fan clicking noise
ouki
The blower fan under the passenger dash is making clicking noise. The higher speed I turn the fan, the faster the clicking noise becomes. It just started to happen today. Was there a write-up showing step-by-step how to open the blower and check out the fans?
Here you go:
-remove 3 screws and disconnect wiring harness
-remove blower fan motor
Sounds like you got a leaf or something in there, clean it out and see if that fixes it.
Here you go:
Thanks IanB. Sorry about your Surf!
Do I need to remove the passenger side kick panel before I can access the motor screws?
I had to only because of the road flare mounted there, got in the way of dropping the motor out. You shouldn't need to on a 4Runner, it's a 2 min job.
Thanks, the Surf will be dearly missed.
2001ATL
