Blown Head Gasket in San Francisco
TRD 4RNR
Member
My 135,000 miles 4Runner has :barf: a head gasket (plumes of white smoke out the tailpipe that smell like antifreeze).
Does anyone nearby have experience and a good recommendation on where I could get the work done at not to hideous a price?
Use the search link in my SIG to explore options.
It can be quite expensive but at least you have choices. Time to read up.
I've never had that kind of work done, so can't recommend a place to do it. I had friend that worked for Pats Garage back in the day. He said they're solid, and my coworker still takes his car there. They are a bit more Honda centric though.
When I had a pathfinder, I had to get all my exhaust manifold bolts drilled out and replaced. G&F Automotive in SSF did a good job on that.
I also see a lot of adverts on CL for motors in the 1300 range. Maybe worth looking into.
Good luck.
How big of a hurry are you in? I might be able to help you out and do it as a side job. I would of course charge less than an average shop, but I may also take a little longer since I do have a full time job.
AlaskaRuss
