Body lift install
4runnin83
How difficult is a body lift install on a 2g automatic 4x4? Is the 2inch easier than the 3inch to install? Any specific tools needed other than a general mechanics set?
I think Bucknut has a BL for the engine clearance, not sure how many of you guys also have it.
Edit: I already have a 4inch suspension lift.
Are you putting in a bigger engine or needing to make room for something else? If not, there is no real reason to do it, especially if you already have a 4" suspension lift. General consensus is that you don't want to go there unless you have to.
Yeah, I have a 350 waiting to be dropped in, and also a set of 36inch tires. I can clear 35s now, but not 36s.
I have a ton of leaks and **** with my engine, and my brother put an LS2 in his Silverado and gave me the engine/tranny and a few other parts. So hopefully by spring I'll have it rolling.
Sweet, now we will have another abomination in the family. LOL! I would talk directly to Bob. I believe with a 3" there are a few odd adjustments to make, but I will let the experts chime in. 2" I believe is fairly straight forward.
I have a 2" BL on both my 83 to make more room for the Buick 3.8/TH-350 swap, and on my 84 so I could raise the fuel tank and entire drive line up to get an almost flat under belly.
Another use of a BL is to accomadate larger tires.
There is a bit more work to installing a 3" lift.
Problems with BL's is BS (unless maybe it's poorly built or poorly installed), I have absolutely no adverse effects from using a BL, and I beat the crap out of my rigs.
Most of the naysayers are going on hearsay and not experience.
4Crawler is your friend. 4Crawler knows all. 4Crawler tells you all about the differences between a 2 and 3 inch body lift... Body Lift Installation Instructions
What he said. Don't buy a cheap kit with small diameter lift pucks. You will put more stress on your body mounts. Roger's stuff is great. I put a 1" BL in mine for a few clearance issues (bolt-on slider brackets and triple stick linkage).
I believe a 2" is simple and a 3" has a few issues. Your transmission linkage, steering shaft, brake lines and possibly the fuel tank filler and body-to-frame electrical connections may be affected.
