body lift or 1/2 inch spacer
shifthis
So I have the Toytec ultimate lift so I guess that's 2 inch rear and 3 inch front. But everytime I wheel I drag the backend. Aside from getting a new bumper I need the truck just a little higher. I was considering a small body lift but that will leave the hitch in the same place and still drag. I haven't seen a rear 1/2 spacer anywhere. Does anyone know where I can find such a thing besides making it myself. Or a 2.5 inch coil for the rear? And how will my ride change adding a spacer on the toytec coil in the back? any? I am thinking I will still be ok with the front axles going from 3 to 3.5 as far as angles are concerned but wouldn't want to go to 4 inches in the front because I think that would severly shorten the life of the front shafts.
You can get an OME trim packer for the rear, it's roughly .4". Also, Cornfed can make you any size spacer you want. I did this and they were great to work with and had the custom spacer shipped out within 24 hours of me placing the order.
I see what your saying, How much did you pay for the 3/4 cornfed spacer to be made? I am thinking I will just do that. As for the lean I have had luck adjusting the front coilovers to correct that. I just need extra height at this point. Any horror stories with the front being 3.75 inch height?
The single 3/4" spacer was $40 shipped. I personally wouldn't run the fronts over 3". I did that with my Overland Warehouse coilovers and the ride suffered. It was more stiff and also didn't have much down travel left so I was bottoming out frequently. If you go much taller in the rear you will run into the same problem. I ended up doing an extended travel setup in the front and long travel in the rear, it made the ride much better since I wasn't bottoming out all the time.
Jhunt
