bodylift is easssy to install.. you need a hi jack lift though with a long 4x4 block is what I used.
id not waste money getting it installed.. do it yourself
loosen every body mount bolt , front two behind bumper, 3 on each side and the rear 2 mounts. then when you get ready to lift one side up.. take out the bolts and lift it up enough to throw the pucks in.
once pucks are in place.. put the bolts in to let the pucks be squared with each hole so the bolts go right through with 5 bucks on one side.. then let it sit on the pucks, hand tighten the nuts.. then do the steering extension. then do the other side after extension and then lastly do the radiator drop if you feel like it.. mine hasnt been done yet but will soon.
you have stock bumper so you want bumper brackets too
www.4crawler.com
only place to get it with everything
i think he means 2.5 inch diameter width pucks and 2 inch width
there isnt such a thing as different size bodylifts
4crawler offerers 2inch od pucks for the front and 2.5 for the rest.
