body lift
skkiii_whhaattt
how much is it to get a body lift installed if i were to take it to a shop? i just got a 2.5" front 2" back body lift kit for my t4r and i wanted to take it to a shop to get it installed because i know its hard to do it myself and it does take a while to get it in there... if anyone could please help me out that would be great!
unless you cant change your air filter by yourself you should be able to do it by yourself in a day taking your time and being careful. go to yotatech.com and search for a write up on how to do it... dont waste your money paying someone to do it, although ive never heard of a body lift that was not just like a 1" or a 2" all around, you might not want to install that lift as it could cause some serious problems
bodylift is easssy to install.. you need a hi jack lift though with a long 4x4 block is what I used.
id not waste money getting it installed.. do it yourself
loosen every body mount bolt , front two behind bumper, 3 on each side and the rear 2 mounts. then when you get ready to lift one side up.. take out the bolts and lift it up enough to throw the pucks in.
once pucks are in place.. put the bolts in to let the pucks be squared with each hole so the bolts go right through with 5 bucks on one side.. then let it sit on the pucks, hand tighten the nuts.. then do the steering extension. then do the other side after extension and then lastly do the radiator drop if you feel like it.. mine hasnt been done yet but will soon.
you have stock bumper so you want bumper brackets too
www.4crawler.com
only place to get it with everything
i think he means 2.5 inch diameter width pucks and 2 inch width
there isnt such a thing as different size bodylifts
4crawler offerers 2inch od pucks for the front and 2.5 for the rest.
