Boost leak between tb and IAC???
68ChargerJMP
Rear mount turbo....I've been chasing boost leaks that all started when I overtightened the band clamp on my maf and cracked it...got that sorted and noticed a leak between the tb and IAC...anyone have this issue or know if I can fipg it to the tb? Thanks.
Before you do anything crazy, it's possible you put the gasket on wrong. I had this same symptom, had a vacuum leak and thought for sure it was the IAC. Took off the throttle body and sure enough, I stupidly put the gasket on sideways. No idea how I did that.
If it wasn't that, replace the gasket between the IAC and TB.
Thanks gfgc.....its definitely the IAC. I sprayed it with soapy water with the intake/charge side pressurized. The gasket on the IAC looked good but probably wouldn't hurt to try a new one.
Put a new IAC gasket on, black FIPG on the solenoid part of the IAC. Found a used TB at the junkyard. Also, replaced the old style MAF with new style. It is running good for now.
The newer style MAF's run rich, but I'm guessing you have a tuning system anyway so that's not an issue. I noticed a difference when I switched with my supercharged system, can't wait to increase boost and increase those gains.
Mike Sargent
