Brake accumulator-master cylinder
4RNRLVR
Anyone have a 2004 4runner master cylinder assembly with ABS unit? Mine is leaking and need to replace, everyone wants $4,200 plus labor.
$723 plus shipping from partsouq
This Toyota PN I assume? 4707060050
Link takes you to the partosuq page.
Please Wait... | Cloudflare
That part number...47070-60050... is the "pump, electric motor and accumulator assembly", which is usually the the most common issue with the ABS/Master Cylinder system, but doesn't include the actual master cylinder....BUT the OP isn't clear when he says "..mine is leaking..", is it the pump assembly or master cylinder leaking(?), it's usually not both but one or the other and as mentioned it's usually the pump/motor/accumulator...most of the time just the accumulator not holding pressure, or the electric motor being worn out.
The pump assembly is $705 at McGeorge Toyota.
2003-2021 Toyota Pump Assembly 47070-60050 | Toyota Parts
