whats up folks, first post here. anyway, I drive a 2000 4runner SR5, blew an axle seal last week, and i knew i needed to do the rear brakes so i picked up drums and shoes as well. I swapped the seals, all that went smooth, so did replacing the shoes and drums. so i bleed the rear brakes, go for a ride, and still have a spongy pedal. Then i do all 4 in sequence from the right rear, left rear, right front, left front. Then go for a ride and still a spongy pedal. I did that same procedure 3 times and still not acceptable pedal feel. The master cylinder never ran dry, i kept an eye on everything. anybody have any suggestions?
BTW, im manually bleeding the system, i've bled probably 100 systems and never had this issue.
Oh, forgot to mention the pedal feels fairly good if i let off and press it a 2nd time during braking, which indicates air in the system. Also, i adjusted the rear shoes properly, there was little to no drag on the drum...im stumped
