never in my life have i heard that. pads are a softer compound than rotors so they will eventually conform to the rotor. if the rotor is warped or gouged the pad will conform to it. the only way a pad could be warped is if the clip holding it in is broken or there is some foreign substance between the pad and the caliper piston not letting the pad sit flush with the piston. in my opinion pads do not warp if there is nothing wrong with the rotor.Rotors aren't the issue. It's the pads giving the "warped" rotor feeling.
When pads heat up they transfer material to the face of the rotor. Once you come to a stop with hot brakes, the pads will imprint more material on one place on the rotor. This is easier to do as pads wear down. Since they are thinner, they don't have as much heat capacity, and they get hotter, transferring material more easily.
The solution? pick up some higher temperature rated pads, or something more intended for truck use. This can still happen, just not as easily.
i have too encountered the 4th gen rotors warp. my pads are like new but thanks to my GF(who is able to warp rotors in every vehicle we have owned) warped these rotors on my '06. the problem with any of these new style rotors are that the are "hubless" rotors which means they are the rotors only, no bearings or hub are part of the rotor. in the old days the hub and bearings are part of the rotor and those style rotors took alot more heat and abuse due to them being able to transfer heat better unlike the rotors of today.
either send them out to be cut(if they are within spec) or live with the pulsation until its time for pads.
Uh...
I've never run across a rotor that was thicker than new? I've also never heard this before. I dunno but I have been wrong before so is this true?
Brake rotors warp easily....
what most people perceive as warped rotors is actually uneven pad material deposition on the surface of the rotor.
Some people understand this and others have never heard of it.
So who really cares if the cause is warped metal or uneven pad material being deposited on the rotor? The end result is the same--the driver feels the pulsation in the brake pedal.
The only real advantage to understanding this problem is to learn how to avoid it in the first place.
The important word here is "perceive".
- There is something called "warp" (albeit rare)
- It is measurable (with the rotors on or off the car)
- But you CAN NOT distinguish between warp & other causes of lateral runout while the rotors are on the vehicle
NOTE: I think that's a true statement ... please let me know if it's not.
Those who understand this, don't use "warp" as the term for something that is decided NOT warp (which, see above, is measurable and has NOTHING to do with uneven pad deposition deposits.
Those who do NOT understand this, use the word "warp" thinking that the rotors are deformed (exaggerated, think potato chip).
I doubt many reliable people would use the term "warp" to mean pad deposition because warp exists and is NOT uneven pad deposition.
It's like calling a tire a "wheel". Those who know the answer know that a wheel isn't a tire and vice versa; those who don't have a clue, don't have a clue and often use the wrong term.
It matters when you're trying to UNDERSTAND the reason for your brake pedal pulsation. Anyone who thinks properly torqued brake rotors actually warp in normal usage is already starting off on the wrong DIAGNOSTIC foot (because you have to solve the problem with a change in braking habits among other things).
You care if you're trying to SOLVE a problem.
- First you UNDERSTAND the problem
- Then you repair the problem (i.e., rebed or turn the rotors)
- Then you PREVENT the problem from re-occurring (i.e., you might change your braking habits to prevent the problem from re-occurring and you'd certainly properly bed your rotors since braking depends partially on breaking covalent bonds).
+1
Yup. My point exactly.
You can't solve it and prevent it from re-occurring unless you actually know what is causing the problem (and it isn't warp!).![]()
