Brand New Trail Edition - Problems Already
dsfra
Member
Not an auspicious beginning...
I just sent this e-mail to the Sales Manager and General Manager at my local Toyota dealership:
My wife and I bought a new 4Runner from your dealership last Monday, 02/20/12. After owning it for less than a week, we are very displeased to be bringing it to your service department tomorrow morning.
A few days after we bought the vehicle, I attempted to remove the antenna on the right-front fender, since I was intending to replace it with a short after-market antenna and needed to see exactly what sort of mount the new antenna would need to match. I first tried a 5/16" box wrench (.3125"), which was a slightly loose fit on the antenna. An 8mm wrench (.3149") would be even worse, so I wrapped some masking tape on the hex at the base of the antenna so the wrench would not cause any damage, and used the 5/16" wrench. After applying what should have been adequate torque to loosen the antenna, it still would not turn. I looked in the 4Runner owner's manual to make sure that the antenna was in fact removable by turning it counter-clockwise, and that it didn't have concealed set screws or something else holding it on. Per the manual, not only was it removable as expected, but I found that Toyota stipulates that the antenna be removed before taking the vehicle through automatic car washes (p. 502), so clearly I wasn't doing anything unusual by trying to remove it. In fact, according to the manual (p. 385), I should have been provided with an "included wrench", "in glove box" [sic], specifically for antenna removal. I looked in the glove box - no wrench. Yesterday, I made a trip to your dealership and talked to our salesperson: he provided a wrench, said that the antenna was installed at the dealership as part of pre-delivery preparation, used the Toyota wrench to try to loosen the antenna, and agreed that the antenna had been over-tightened when installed. He finally got the antenna to turn, but it was not turning independently of the mounting base - the assembly inside the base was turning. I was concerned about the antenna cable getting pulled or twisted, and suggested that someone from the service department look at it - the base of the antenna and the guts of the mounting base were now loose and moving around inside the fender. No one from the service department was available, so it was suggested that I make an appointment with the service department, which I did for tomorrow morning at 8:30. There is now no radio reception for either AM or FM - only static.
When I show up at 8:30 tomorrow morning, I would like to discuss with your service manager exactly what will be involved. I assume, since the antenna base itself (part 86309E) inside the fender is apparently damaged, that either the right-front wheel, wheel flare, and inner fender liner will need to be removed to allow access through the wheel well, or the panel running across the base of the windshield and under the rear edge of the hood will need to be removed, along with the wipers, to allow access from under the hood. In the former case, my hope is that no part of the right-front suspension will need to be touched.
I never would have expected to buy a $40,000 vehicle that, within a week of delivery and after 76 total miles, needs to be brought back to the dealership and be torn apart for repairs.
While I hasten to add that we had a good experience dealing with the sales staff when buying the vehicle, these subsequent problems have detracted greatly from the experience.
Consider yourself warned: If you haven't tried to remove your antenna yet, be real, real careful...
We're hoping that this first week of ownership isn't a preview of what's to come. We're looking forward to retirement and lots of red dust in Utah before too long.
Sorry to hear about your experience. Hopefully after this hiccup you will have many trouble free years with your truck. Good luck!
Sure am. We're talking about a dealer service department here. The guy will probably bump his head on the caliper and decide to get all that springy stuff out of the way. Just kidding - but several marginal experiences with dealer mechanics in the past make me worry.
You aren't the first to break the antenna trying to install a stubby and you won't be the last. Hopefully they won't have to remove the tranny to get it fixed.:lmao:
:jk:
No offense, but that's a rather small detail to be getting all up in arms about, and thinking the rest of the truck is likely to start falling apart because of an antenna fitting. You sound as if someone had to twist your arm to get you to buy this truck, if you're so ready to turn on it over this. I'm sure your vehicle is NOT going to be lying in a heap of parts in your driveway overnight, so try to calm down and get past this insignificant little blip. Either that, or go trade it in for that Chevy or Ford that you seem to have really wanted, and let someone who knows what they've got enjoy your former Toyota while you deal with some REAL problems.
I dont think people should be too rash about it and jump on the guy.
It was a simple mistake, it will be a simple solution, and i'm sure it will be replaced by the dealer without issue.
i've never really seen the point of replacing the factory antenna with a stubby. half the people seem to get great reception and half seem to get terrible reception.
there is an entire thread in the 5th gen forum about the shorter antennas that you should check out dsfra, lots of good info and experiences on there.
also, i believe if you wrench on the antenna with a set amount of torque it'll just spin on the base and indeed damage the connection. what others have suggested is to try a quick flick of the wrist and break the antenna loose first.
the antenna may stick due to other reasons besides over tightening such as rust or gunk getting in there.
hopefully this doesnt spoil your golden years and i can assure you the 4runner was an excellent choice as a retirement travel vehicle :D
good luck
DSFRA your post was good. Don't let a couple very strong opinions turn you off this group. There is a lot of valuable information here, but some people's emotions interfere with the tone of their posts!
so you're basically saying in a nice way that some of us are *******s :fishing:
Update
Granted, the e-mail I sent to the dealer was very specific and to the point, even boorish perhaps, but I didn't want to spend time rewriting the story in a more casual, forum-ish tone before posting it here, so I just pasted it in and let fly. Thanks Carl, not to worry - I have relatively thick skin.
I did, in any case, succeed in getting the dealer's attention and subsequently getting the issue resolved:
Went to drop off the vehicle this morning and was met at the door by the service department manager, who assured me that they would remedy the situation, explained exactly what they would be doing, and said they would take pics of what they found. They determined that the antenna was way overtorqued when initially installed (at another dealership), and the wire running from the base of the antenna to the cable connector broke when the antenna was removed. They didn't have a new base assembly in stock, so they borrowed one from a new 4Runner on their lot to avoid waiting 3 days for a new part to arrive. Got a personal visit from the general manager on the way out - most appreciative of my business and promising to do a bang-up job henceforth. High viscosity warmth and fuzziness for everybody.
Then arrrrrgggg, it's always something. Asked the service manager where they hid the tranny dipstick - turns out that the tranny is "lubed for life", and if you ever want to flush the fluid, it must be done at the dealer's since they use some sort of computer-controlled flush/refill equipment. So much for doing frequent flushes myself - anticipate doing lots of towing so wanted fresh fluid in there at any given time. Oh, well...
Finally, a belated "Thank you" to the people on this forum - I spent a lot of time here when trying to decide between the 4Runner and the likely competition (such as it is), and then between the SR-5 and the Trail Edition, and then KDSS vs. non-KDSS. Thanks for all the input.
My wife and I bought a new 4Runner from your dealership last Monday, 02/20/12. After owning it for less than a week, we are very displeased to be bringing it to your service department tomorrow morning...
At least your dealer didn't install a beige pinstripe extending the full length of your black 4Runner without asking (as mine did).* :mad:
*They are removing it next week.
2012 Trail Edition, KDSS, Nav, and NO Running boards dragging on the rocks, towing Chalet Alpine high-clearance camping trailer whenever possible
Pics of said boardless Runner and high-clearance camper please!!!
Sorry, but this time of year in Seattle there's not enough sunlight to take pictures, so for now it's gotta be the trailer behind our dearly departed, much-missed, slightly butt-dragging, just traded-in-on-the-new-4Runner Mazda Tribute. Hope posting a non-4Runner here doesn't get me into too much trouble. It'll be nice to have the additional 1500 lbs of tow capacity available with the 4Runner. We have the route to Moab all planned out - finally heading for the White Rim Trail in Canyonlands. Any guesses regarding a stock TE on the Flint Trail?
Anybody know if it's possible to use the 4Runner's rearview mirror backup monitor for a camera mounted on the back of the trailer? It uses an old-fashioned RCA phono co-ax connector. We have Nav/GPS on the 4Runner so it uses the Nav's monitor rather than the one in the mirror. Don't know whether the mirror really has an un-used monitor in it, or if Toyota actually uses 2 mirrors - 1 with monitor and 1 without. Guessing it's cheaper for them to just make one mirror and install it whether the vehicle has Nav/GPS or not.
Nice setup! Seattle.....very nice. We try to get there once every few months. Our favorites: Pike Place Market, Crab Pot, Delaurenti Deli.
Nice set-up! I like the A frame camper! Only 2 of you obviously.
Two mirrors so that may be the way to go, get the mirror w/screen and a cam for your trailer. Whether or not it can be integrated into the nav I can't answer, PM Antman I'm sure he can answer that.
Also glad to hear your experience at the service dept was a positive one and that you got the antenna all fixed up :thumb3:
Carl - You guys in Vancouver have us here in Seattle beat by a mile: Stanley Park, Lions Gate Bridge, great waterfront and harbor area, Capilino Bridge, Grouse Mountain, False Creek with its funky little boats, Grenville Island, and the occasional old Mini Cooper. All we have in Seattle is the old Space Noodle left over from 1962 and a really ugly waterfront area that they're now tearing up to build an ugly tunnel to replace the ugly viaduct.
Qjake - Yeppers, we love the trailer, which by the way will actually sleep 4 adults, especially if 2 aren't too large. There is a dinette in the front and a dinette in the back, both of which convert into beds, plus fridge, sink with hot and cold water, furnace, tank for 15 gallons of drinking water, outdoor showerhead, and 2-burner propane stove. We've had good luck towing with the Mazda, sleeping in the trailer, and then when the roads get too bad we just drop off the trailer, have fun on the bad roads for a few days camping in the back of the Mazda, then pick up the trailer on the way out. Now with the 4Runner we'll be able to really get ourselves into some even worse spots. We plan to equip the 4Runner like we did the Mazda - take out the rear seat cushions and put in custom plywood storage boxes that extend the flat cargo area for sleeping, plus the suspended shelf in the back for convenient storage at night of books, flashlights, snack and drinks, etc.
Can't wait to get the 4Runner set up for this summer and get rolling - hiking in the Great Pacific Northwest, Utah, and hopefully the Canadian Rockies. Just in time for $8.00 gas. Then, next year, Alaska and cross-country with Yellowstone, Glacier, Maine, and Florida. Looking forward to this retirement stuff. Have had 'nuff of this working crap - now just have to keep the spouse working a few more years.
REE
