Bright non-HID bulbs?
Stuck CAPS
Looking for some whiter and brighter lights up front in the lows, highs, and fogs. What are some good options for non-HID, bright, white lights?
My HIR bulbs in the high beams are very bright, but not that white. I have HID's for the low beams and the color difference is a lot.
I have HIDs for my low beams as well, but the high beams (stock) are pretty pathetic. Where did you get your HIRs?
Sylvania SilverStar Ultras (4100K) for the headlights and Hella Extreme Yellow (2500K) for the fogs.
I tried 5000K headlights and I couldn't see chit under dark and wet or dark and foggy conditions. Plus, under those conditions, the Hella's provided some kick-azz contrast.
not to sound like a jerk but you didnt search enough, the HIRs are for 03-05, the H9 swap is for 06+. http://www.toyota-4runner.org/4th-gen-t4rs/69166-high-intensity-infrared-hir-bulb-install.html on a side note, the stock low beam bulbs have a cap on them, the hirs & h9 are brighter, have no cap & throw light farther & wider down the road. basically a high beam bulb in a low beam spot, so you might want to aim the headlights down a bit. hir & h9 also dont last as many hrs. compared to a regular low beam bulb, some say the same for the plus bulbs, so that may be something to consider. http://en.wikipedia.org/wiki/Headlamp
not to sound like a jerk but you didnt search enough, the HIRs are for 03-05, the H9 swap is for 06+. http://www.toyota-4runner.org/4th-gen-t4rs/69166-high-intensity-infrared-hir-bulb-install.html on a side note, the stock low beam bulbs have a cap on them, the hirs & h9 are brighter, have no cap & throw light farther down the road instead of wider & closer to vec. so you might want to aim the headlights down a bit.
No worries, thanks for the info. A direct fit is even better.
dont let that throw you off, if more light is needed, the hirs & plus bulbs have higher lumens & are a great upgrade, but also cost more $.
charlesz
