Brighter reverse lights
No worries man, they are a direct plug and play... I put the same ones on mine, a bit of work but easy enough.
And they do indeed take the 921 bulb which is bright enough for me so far... but there is always room for improvement.
Got them installed. Not the best fit but I made it work. And it's a 921 bulb. Pulled it out to make sure. Now I've just gotta order some LEDs for the reverse and turn signals.
Did you put an led in your third brake light?
I had to leave a regular bulb in mine to keep the abs light from coming on...
Sent from my A100 using Tapatalk 2
I thought it would be either wiring or something related to the new lights since that's all I touched. Maybe I missed reconnecting a ground or something? Or is it that the new lights draw less power?
I didn't mess with the 3rd brake light. It was out before I changed the lights.
Yep, the new lights draw very little power. If your third is out, replace it with a standard bulb, it should draw enough to keep that pesky ABS light off... worked for me.
Thanks guys.
If case anyone wanted to know.......these are Anzo brand but on each light is stamped "Eagle Eyes" so it looks like companies just rebrand the same units. Except for depo I believe.
Mike Sargent
