Broken headlight adjuster.
Menace Kustoms
Are the adjusters themselves replaceable? Or do you have to buy a whole new assembly. The part that holds the adjuster to the headlight bracket broke off, and the headlight won't adjust.
My headlight housing broke when I hit a deer last year - The portion that held the adjuster, like you are talking about. I just used 2-part plastic weld epoxy to fix it. It is holding up fine, and I can now adjust the headlight too.
Don't replace your OEM lists with EBaY . Huge mistake.
The adjuster assembly can be purchased for about $35-40 per side and easily swapped onto the light assembly. It would take less than 10 mins after you removed the light from the vehicle.
Where to buy? Google: "Camelback Toyota Online Parts"
Call them, ask for the part number, hang up, order it online at their online parts store.
jesslstn854
