What is this piece called, part number, for retaining ring headlight adjustment
JoshFink
Junior Member
Hi, I was going to adjust my headlights and I noticed that these retaining rings that attach to the white gear for the headlight adjustment were broken.
I 3D printed some replacements but I was wondering if someone might know the original part number for a 2002 4Runner. I could not find it at all but it might be my lack of the correct keywords.
Thanks for the help
Unfortunately, I have done all that. I'm guessing it's a keyword issue. I spent several hours looking for it earlier and the dealership was no help either. ¯\_(ツ)_/¯
Thanks though.
Not available separately, you have to get the whole "frame" (Toyota calls them housings).
Thank you. That's what I was afraid of. I'll make due with the 3D printed piece until it stops working. So far so good with it.
There is also a difference between the OEM and aftermarket adjusters. The aftermarket ones are much weaker and break more easily...
-Charlie
-Charlie
Considering that I couldn't even find an aftermarket one, I'll take your word for it. ¯\_(ツ)_/¯
So far the 3D printed piece is holding. We will see how it holds up 6 months and a year from now.
I mean the adjusters that come with headlight units that you buy aftermarket (Depo, etc.). Either way, the parts are not available separately.
-Charlie
You're better off sticking with the OEM "housings" anyway. I've had two or three aftermarket headlights and they all fit like crap; like you can see how warped the housings were before bolting down one of the lower mounting locations (must've been sourced by the same manufacturer because they were all warped this way) and the metal filler panel between the bumper and headlights never lined up as level as OEM. I ended up throwing out the aftermarket housings and reuse the stock ones to mount the aftermarket lights.
Thanks for the help
Not sure of the exact part number, but Toyota usually sells the entire adjuster assembly, not just the retaining ring.
Might be why it’s hard to find individually.
Funny how tech keeps sneaking into even the most unexpected parts of life—whether it's fixing your car or updating your contact details. I recently ditched the paper business cards altogether and figured out how to set up a digital one right from my iPhone. This guide here actually made the whole thing super straightforward. Didn't think I'd be that person showing a QR code instead of handing out cardboard, but it’s been a game changer—especially when you're juggling too many things at once and still want to look professional.
DJNutshell
