Broken Sparkplug, Please help!!!
T4R Russ
Just like to say Hi to all I am glad that I found this forum.
I just bought a 94' 4rnr, V6 with the manual trans. I was doing
some regular maintenance on it change fluids, wires, cap, rotor,
and sparkplugs. Everything was going pretty good, I had
changed 5 of the 6 plugs when I got to the drivers side rear plug
it was pretty hard to turn, well about 1 1/2 turns out the darn
thing broke flush at the bottom of where the socket grabs
leaving the threads behind almost all the way in, the ceramic
insulator in the center came all the way out so now I have what
looks like a smooth sleeve inside there. Went to autozone and
got some penatrating oil and an easy out soaked what was left
in the spark plug hole overnite and went out this morning put
the easyout in with a 3/8 socket and a very long extension with
a breaker bar. Once it grabbed I started to apply more and more
pressure gradually until I actually twisted the extension at one
end almost breaking it, by the way it is an 3/8 extension.
Has anybody had this happen or know of this happening?
What should I do, remove the head, try and drill it out in place?
Any help would be greatly appreciated.
Russ
Just to let everyone know I finally got the sparkplug out, thank
god :awais: all I did was went back to autozone and got
some "PB Penatrating Catalyst" sprayed it on the stuck piece
and waited for about a half hour and it came right out.
For those of you that do your own maintenance and for those
who don't make sure when you change plugs or for that matter
use any steel bolts into aluminium make sure you or your
mechanic use antisieze. If i could not have removed the plug it
would have cost me over $300 in parts to do it myself and my last
quote from the local shop was over $1000 just becouse whoever
owned this thing before me would not use $5 worth of antisieze.
FYI all the machine shops I called said that it is real common on
Toyota's.
Thanks For all The Info I have Found On This Forum,
Russ
Good ol' PB Blaster! Great stuff!
Glad it came out! Yeah, like fourwd1 said, removing the head is the best way to fix that.
Yeah, anti-seize is good stuff!
