Budbuilt Slider Install Help
Tips:
In the last pic with the brake line, you'll neeed to add washers or spacer to get the line to clear that threaded plate shown to the left, just behind the gas tank skid.
Also, I had a hard time getting the rear bolts on the drivers side to catch on the threaded plates that go up between the frame and gas tank. I bought a couple slightly longer bots and got those tightened down along with all the other bolts to fully seat the long plate that the slider is welded to. I then removed those extra length bolts and was able to use the bolts Bud provided so that I did not have any clearance issues with rubbing on the plastic gas tank
Feel free to ask questions or PM me if you have issues?
- Mark
Greydog, thanks for sharing the instructions with everyone!
Managed to snap a bolt removing my gas tank skid and have been having trouble accessing the bolt blocked by the drive shaft (need to get a pivoting joint socket).
Anyways, after I take care of those problems it looks like the install will go great and will share out afterwards.
Ya, that bolt blocked by the driveshaft was a pain. I think I may have left it alone and just bent the skid down :)
tuṣṭāva
