Build Thread: Mothra, the (blown) budget camping rig
Status
Not open for further replies.
Camping Trip to Garner State Park
We had the weekend off and wanted to get out and do something. We were able to get into Garner State Park in Uvalde County, TX.
It is beautiful there and I highly recommend it. There are lots of camping spots and hiking trails. Unfortunately, a cold front blew in while we were there, so that did make the trip significantly colder than expected, and ruined any kayaking or fishing we were going to do.
New Rubber
A couple weeks ago I went to get my tires rotated and was informed that at the current wear rate my Falkens would not make it to 30k miles. I have already been mad at the Falkens and as weird as it sounds, every time I walk by them I get irritated. I started looking around and narrowed my tire choices down to 2 tires; The Nitto Ridge Grappler and the Goodyear Duratrac, both in 285/70R17.
The Nittos have good reviews, but are new, just like the Falkens when I got them. The Nittos are available in a C range tire. They are also fairly light, for LT tires.
The Goodyears have been around for about 8 years. They are available in a D load, but are light (54 lbs). The design has been unchanged for long period, so that tell me that the tire is solid and quality is good. I have had Duratracs before and they were great.
I went to Discount and asked about both. The Nittos are specia order only and price is not negotiable. The Duratracs were in stock and I was able to negotiate a price of $1009 out the door. Pretty good, and I'm much happier with them.
I was able to sell the Flakens to recoup my cost. 4 285s fit perfectly in the back in case anyone was wondering.
Liking the bed liner. Did u spray or roll it ?
Thanks, it's spray on Raptor Liner. Spraying is very easy, but I think if I were doing it again I would roll it on either with Raptor again, or Monstaliner. I bought a huge compressor and it struggled hard to keep up, so some areas look better than others because the pressure was all over the place, even with a regulator on the gun.
I've never heard of painting your truck with bed liner. What a clever idea!
Did you do it for the look or for extra protection?
Does the texture have any negative impact on MPG? Does the liner/paint bond to the truck quite well?
I think it's a fairly new idea, maybe past 10 years or so. It is more popular in the Jeep community. I did it because it was much cheaper than a traditional paint job and my original paint was trashed. It is also easier to keep clean and "scratch free". It is hard, it's a 2 part epoxy so when it cures, it isn't going anywhere, as long as the surface underneath is intact.
I haven't noticed any change in MPG, I was thinking it may help as it would disturb the air going over the surface, but nothing noticeable. I get 16-18 MPG mixed in the truck and I'm happy with it. It does seem to offer a little noise reduction from the exterior, but that may be my imagination. Most of the noise on these trucks seems to come from the roof and windshield.
I had previously done my old Jeep and it was great. If you get a quality liner it is color-safe. The cheap black stuff from walmart/autozone wont last a year in Texas.
That's so cool! Way better than getting the rig wrapped. And it makes perfect sense that it would protect against (or at least hide) scratches and dings. I mean that's the primary purpose of a bed liner, anyway.
I love it.
Edit: Is it harder to clean due to the texture? Lots of nooks and crannies for the dirt to lodge in, no?
I love it.
Thanks.
I think it's actually easier to clean. Just hit it with a power washer and it's good to go. The texture isn't that rough that it traps a lot of dirt. It's like thick, unscraped wall texture.
Fuel Injectors and knock sensor harness
I have been feeling like this truck is down on power, especially since riding in a friend's runner. I did briefly get a misfire code a couple weeks ago that went away and hasn't been back. I know the ignition components are good, so it has to be fuel. I figured if the stock injectors have made it 273k miles, they are probably pretty tired. I ordered a set of OEMs, at least advertised that way, and figured I'd do knock sensors and knock sensor wire while I was that far down in there, since that could cause problems later in life.
First I checked resistance on the front 2 injectors on the passenger side, since they are easy to get to. 19 and 22 Ohms, that's pretty far out of spec.
New Injectors look slightly different than the old ones, once removed but have Arram on the side and seem well made. They had 14.1-14.4 Ohms resistance, much better.
The new knock sensors were suspect. Both advertised as Denso, they both arrived in a carboard box, wrapped individually in bubble wrap, both say Denso, but one looks odd. It has a hole in the bottom, there the threads are, also the word Denso looks like a bad casting. Seems like a knock off part. I elected not to install them, and will be requesting a refund. Knock Sensor harness is cheap and arrived in a sealed Toyota bag, good to go.
@%1; gave me a hand with this operation today and it was a success. It took us around 4.5 hours to do this. We also wrapped the wire harnesses by the valve covers with wire loom. The casing cracked off while doing the valve covers and it was bugging me that the wires were rubbing on the valve covers with no protection.
It was determined that removing the hood would be easier to get the work done, so it was removed. I'd highly recommend doing this when working under the hood for any period of time. It would probably be had to do alone, but with a hand, it's simple and adds about 5 minutes total to your job.
Valves look pretty good, but I have a ton of oil in the front passenger and rear driver cylinder head intake ports.
The fuel injector ports were pretty disgusting, as was the whole lower intake inside and out. Something made a nest down in there at some point.
Old fuel injectors look like they've seen better days. After checking resistance after they were out, all were around 16.8 Ohms. I'll be keeping them in case the new injectors don't work out. The 4 ports under the actual injector didn't line up perfectly with the 2 holes in the tip, on the new ones, but did on the old ones.
Time to reassemble, was a pain in the ass to get the fuel rail back on straight, probably took about an hour to do.
That wire loom:
Got it all back together and took it for a spin with the hood off, because why not.
Overall, it feels a little smoother, much better power above 3000 RPM, feels similar under 3. This truck runs well as long as the temp is below exactly 80 degrees. Whenever it's hotter than 80 it's a total dog, so we'll see how it holds up in the long run. Today was a cool 74 degrees in Central Texas.
My dad has been looking for a good "cheap", reliable vehicle to daily since he's having some issues with his Jeep and their old suburban needs more cost in work than it's probably worth. We looked at a bunch of 4Runners and found a great deal on this 02 Sport. It has 223k on it and is in pretty good shape. It seems like every single 4runner out there needs the exact same things done; all suspension replaced, valve covers, and lower ball joints. Some needed rear axle seals, and new power antennas. He got a smoking deal on this 02, so he snatched it up. It needs some refreshing done, which I'll be doing in the next couple weeks.
Not really a build thing, but we had a pretty good snow storm move through and of course @%1; and I were at work for it, which made for a long night. I can not remember having snow like this ever in Central Texas. Almost 3" of accumulated snow. That's a lot, when you put into context I was wearing shorts, flip flops, and a T-shirt less than 24 hours before.... Some pics
That's some crazy weather there for sure!
This thread makes me want to test my injectors (resistance) when I pull the upper manifold to do my HGs
Dat wire loom doe :D
Awesome build!! Love all the DIY stuff! Have you thought about painting the wood on the trailer the same as the truck and painting the wheels black? I think it would look killer matching your truck
Sent from my Pixel using Tapatalk
I really like the bedliner.
Do you still have your jeep ? If not, do you ever regret getting 4runner ? What are some things you like and dislike between the two.
Yeah, why not? I sent them to Injector RX in Houston. Cost me $125 to have them checked and cleaned. plus they flow tested them and somehow brought their resistance down. Well worth the peace of mind for another quarter million miles. Yeah, I just pulled all the plastic out and put the wire loom in. much better. It was always in the back of my mind that the wires were just in there with nothing to keep them from rubbing the top of the engine. Talk about a literal nightmare if a wire rubbed through.
Thanks, I had to do DIY work, that's the only way I can even try to pass this as a "budget build".
The wood on the trailer is actually sealed with urethane, so its pretty well protected. I considered painting it various colors, including tan. I decided I liked the classic beauty of the wood grain. Yes, the wheels need to be painted badly. Really, it just needs new wheels that are bigger, but then I wouldn't be able to fit this in the garage anymore.
I'll probably sell this one eventually and make another one that has bigger wheels, but a lower sides on it, or no area under the tent.
Thanks!
I sold the jeep after I bought the 4Runner to pay for more mods. I don't regret selling the Jeep. It was fun, but it was a labor of love. It needed a lot of work, I had already done a lot of work, but after 40 years of it passing through countless owners, it was a hodge-podge of parts from various generations of jeep and I just got fed up with trying to figure it out. Also, it was totally impractical, I had no doors or top for it. It had no heat or defrost, so it was nice weather vehicle only. It was also not amazing offroad. Carbs and old 3 speed manuals are hard to rock crawl. Once the angle would get too steep it would try hard to flood itself. It was, however very very cool to just cruise in. I live just outside Austin and would take it to car shows, and cruise the South Austin strip "SoCo" and it turned heads EVERYWHERE with its loud sidepipes and clean, but rugged look.
The 4Runner is a much more refined vehicle with a lot of nice modern amenities. Things like windows, a radio, and air conditioning go a long way when you're driving around. Also, when we have kids, I'll have no hesitation throwing a car seat in the back and driving around with kids. The 4Runner is easier to get the right parts for and theres a lot more detailed and accurate information.
So I had a fairly open day today and got quite a bit done.
I went and picked up a bunch of parts for my dad's runner. I checked my transmission fluid the other day and it was looking kind of brown, so I decided to drain and fill it today, did that twice. I've seen a lot of varying numbers for trans pan volume, from 4-6 quarts. Mine is exactly 4.1 quarts. Which is great because I bought 2 Gallons and an extra quart. I drained it, and filled. let sit in gear for a few minutes, then drained and filled again. Looks much better, drives the same...
Top left is old, middle is after "flush"
Also, discovered I have another piece to replace.
I have had some ball joint bolts laying around for a while and decided to take the old ones out and replace them, with loctite, one at a time so I didn't have to jack the truck up. Easy peace of mind.
I have been having a hard start issue, so after some good input and research, I bought a new MAF, since this old one is likely the original. No more hard starts, so far.
Also put in a genuine Toyota PCV
And the most exciting thing I did today:
I installed a switch for the power antenna. Now it's not up all the time. I listen to the FM radio almost never, so it always bugs me that the antenna is ALWAYS up.
It's the small things in life...
How did you wire the switch for the power antenna? My understanding is you have to cut the wire from the original harness?
Status
MaximussK
