Bulb out on dash (pics)
voda48
Hi all,
So my wife's 4Runner has some bulbs that burned out. I found this post Changing Bulbs in A/C unit! and was able to take care of the A/C Unit bulbs easily however I find that I now need to replace a few others. Unfortunately my wife did not want LEDs so I am trying to find the Toyota parts # for the bulbs that go here:
I am not sure of there is one or two bulbs, I was only able to remove one. The other possible bulb wasn't very accessible (i.e had grip on the back to remove with). Here is what the one bulb looks like:
Does anyone know the parts number for this? Are there two bulbs in this area or only one? Thanks all!
It's a dealer only part. One is taller as shown-one is shorter-take one in to the stealership and they should know what you mean...
Check your ashtray light while you're at it...
Yup had to get them from the dealer, $8 for both. The other one is harder to get out for some reason but just turn it and grab it with a tweezers. Never knew what I was missing with those lights burnt out.:banana:
Bulb missing behind "check engine" window!
I wanted to check my bulbs behind the dash, so I removed it and started checking them. I found that the bulb behind the "check engine" window was missing! What idiot... Anyway the others were fine. I did need to replace a bulb behind the heat/AC window and in the glove box. The bulbs were pretty inexpensive and easy to replace.
Thanks guys. Do you happen to have the part numbers on hand or should i jsut want in with the photo?
FYI - I found the bulb part numbers for the two bulbs in this area if anyone is interested:
There are two bulbs here and you will need:
1x 90010-10042
1x 90010-101041.
I bought them from the dealership for $4 each and had them swapped out in 6 minutes (I was bored so I timed it).
DJNutshell
