bumper build question
ocreptileguy
I picked up some tube to start building my front bumper. Went with 1 3/4 120 wall DOM tubing. Does anyone know of a free blue printing program to draw up measurements and what not. I hand drew the look I'm going for and would like to build a schematic for it.
Bumper will bolt on to frame rails, and be a hybrid bumper. I don't plan on adding a winch.
I have access to all necessary tools for the build. I want to be as prepared as possible and not waste metal
Thanks in advance
Probably not as detailed as you'd want but google sketchup is free and pretty sweet to use for building designs. Idk how well it would work with tube but.....its better then the other replies so far....sorry I dont have abetter answer for you
if you have a .edu email adress you can get autodesk inventor for free. you can also use tinkercad which is powered by autodesk for free online.
if you are able to get inventor you would need to make a sketch for the shape of each piece of bent tube, then sweep the profile of the tube along it.
Philthyphilthy
