bumpstop upgrades?
4x4runner2002
so i wanna upgrade my bump stops front and rear.
i see that wheelers offroad has the timbren bump stops. Anyone have experience with them?
i think i read that someone used the 05+ tacoma wheelers super bumps, but i cant find that thread again.
any other ideas?
Are you working those shocks that hard already? But I need to do the same with mine on the bumpstops, I'm hitting hard when I'm bottoming out. I'm really saving up for airbumps but haven't got that far yet.
These are 2nd gen Tacoma bump stops from wheelers offroad. They work great on the 3rd gen as well.
http://www.wheelersoffroad.com/05uptacomasuperbumps.htm
No. Not yet. I planned to make a go pro vid but I haven't had time. They compress to half their size. So compressed they are the same six as stock.
To give you some feedback I find them amazing. I have sway bars removed front and rear with icon 2.5 on all four corners. The back I never felt bottom but the front I did. A hard slam at full contact. With these I feel like the icons in front have a more progressive feel.I can push harder at high speed. There is still a bottom out but it is not nearly as noticeable. These are a great step up from the day stars. The day stars are a waste of money. There are basically the same as stock. I'm probably going to end up installing jounce stops in front to produce that truly bottomless feel.
Ya I took some hard hits this weekend doing 60 in a wash.
For the rear I think imma get the daystars and make my own spacer with square toob.
The front I'm leaning towards the 2nd gen tacoma super bumps.
There is a video on you tube of a tacoma with them. You can see the compression real good.
Did you replace just the rear ones up front or did you do all 4?
Hmmm, these are tempting. I've been looking for a good / cheap bumpstop solution for the front. These might fit the bill nicely...
The front of the front.
The guy at wheelers said to do the rear of the fronts if doing just one on each side. He said that's what the timbrens do.
Interesting. I did the front of the fronts. I don't feel them at all. I thought they only used one per side
any other ideas?
are you looking to get longer stops or shorter ones ? Ive replaced my stock ones with low profile bump stops, which allow for more travel :biggrin1:
I just want it to be smoother. Right now the stick ones are pretty hard. I have the ext travel icons.
And in the rear my bumpstops don't even touch at full flex so I need to lengthen them for sure.
freddygino
