Buying 2003 T4R
jm47
Hi Everyone: I am thinking of buying a 2003 4Runner Limited and am not sure if I looked at everything I should have. I took it for a test drive yesterday and everything seemed to be ok. According to Carfax, it is a one owner, 86k mile,accident free vehicle. I had a 99 T4R that seemed to drive much more "trucky" than this one. There are a lot more bells in this one than the 99. I just want to make sure I am not overlooking anything. It did lurch when it was in low 4WD. Thanks...
2003 Info
Thanks CSX for the links I should have looked for before posting. I didn't find a lot of info on my particular situation. I found a nearby mechanic who will go over the Runner for a fee. The seller has agreed to this. This seems to be my best option...
Where is Home?
What part of the country are you located. Different areas seam to have comman things to look for depending were you area or where the truck is from.
Like you, I came from a 3rd gen to a 2003 Limited and absolutely love it. With so many bells and whistles don't get overwhelmed, half the fun is learning all the tricks.
wow that is extremely low mileage for the age. I'm guessing around $15,000..? anything that low miles would be sold instantly in my area (Raleigh).
If it's a V8, they need a timing belt job (~$800) at 90,000 miles so ask if that's been done. Irrelevant if a v6. Having a mechanic look at it/drive it will be the best bet so that's good that you are doing that.
No worries, it takes a bit of time to find your way around. It sounds like a good option! Hope you found a good one, the key in my opinion is past mainenence.
Thank you
Thanks to everyone for all your input. I am located just north of Boston. The seller is asking $10.5k (firm) for the vehicle. I found it on Car Gurus. It's a V6 so it won't need a timing belt. The tires are Bridgestones(I think) with a decent amount of tread. Not a whole lot of history with service records on the Carfax. Pics are available if you google Atlantis Auto Framingham Ma. I've put a refundable down payment on it. I bought my '99 in '08 with about the same amount of miles for $8500. It was a great truck until someone blew through a stop sign and totaled it. That truck was nine years old when I got it. This one is thirteen. That is a concern. Edmunds has a bunch of reviews for 03s and everyone seems to love theirs. I also had a brand new '90 until the rust got to it at 250k miles...
How many miles are on it?
Read up on the 4th gen V6 head gasket issues in the early 4runners (2003 - 2005). Lots of folks on this forum have had their head gaskets fail on them in their early build 4th Gens.
Ensure that there are no check engine lights on. Perhaps get a code reader and check the system for any stored error codes. P0306 comes to mind.
If everything else checks out, you could always pick it up cheap and then just have a side budget just in case it fails.
WOW! I SAY GO FOR IT!
My 03 has been great!
Most of the 03's seemed to have avoided the V6 Head Gasket and Back window shatter issues that seem to plague the later 4th gens.
Make sure to check underneath for rust. If it was incredibly rusty, that would be a deal breaker for me.
Good luck!
Thank you again
I will mention to the mechanic that's going to look at the vehicle about the head gasket and the rust. What I saw under the truck didn't look too bad. The only mechanical issues were a very slight ticking sound when the truck was started which went away as the engine warmed up. The other issue was the lurching in low 4wd on drive pavement which I probably shouldn't have done. Again, thanks to everyone for all of your great posts!
The V6 does have a characteristic tick to it from what I've read and heard on mine.
The 03 V6 has a 4 speed tranny. The 05+ V6 has five speed. Makes a huge difference IMHO.
Still 10.5k for a low mileage 03 seems like a great deal.
Good luck!
I agree with BRUIN, I also have a 03 with just over 167K miles on it and runs great. From what I've seen and read about the V6 Head Gasket issues is that they were mostly on the 04, 05 and a few 06 model years. But you should have your mechanic check it out just in case.
Pic Link
Sorry about that bad link. The best way to them is to Google Atlantis Auto Framingham Ma. Third one down in the Inventory. Thanks...
I have a 2003 V8 with 160K. It drives as well today as the day I drove it off the dealer lot. I think the engine is bedded in now and I'm planning for another 160K. As long as it checks out with your mechanic, and the rust is under control, you should be fine.
If it has XREAS, plan to replace that at some point.
johnnya
