Cali-Raised Tri-Color LED Fog Replacement Bulbs
weaselbob74
Has anyone tried the Cali-Raised Tri-Color LED Fog Replacement Bulbs? Seems like an awesome idea if the light throw is nice, but there are no street shots. How do you control the color changes?
I was thinking about doing something similar for the DRLs. I would love amber for the DRLs but White for the high beams
Tri-Color Fog Light Replacement Bulb– Cali Raised LED
Saw this on their Instagram page yesterday and they said the different lighting modes are controlled on a switch to cycle through white light, yellow, white/yellow. I'm also curious to see the actual light output other than against a wall.
how do you cycle between the colors? does this come with a switch or is it a matter of turning the fogs off and on to cycle them through?
A while back I did a review on the BOSLLA BULLET. It’s essentially the same thing as these and the way you scroll through the light modes is by turning on and off the fogs via factory switch.
Search the forum for “ BOSLLA BULLET REVIEW” I’m sure it will pop up. I think I even have pics.
Found it:
BOSLLA Bullet H11, review.
Found it:
Just saw an ad from Cali-Raised and thought about these again. I emailed CR and they said you do cycle through the modes like the Boslla Bullets and they default back to white, in case anyone was wondering
These look interesting.
I would hope the default mode would be user adjustable. So you can choose whether it would be combo, white or yellow when turned on.
Crookedcat
