California 99 4Runner - looking to replace both Catalytic Converters
I would weld in some universal high flow's. Aftermarket direct fit's are the same universal stuff you buy at Autozone with piping+flanges to make it bolt in. The quality is miles behind OEM anyway.
Thanks all for your replies.
Turns out it was my muffler.
Wow, what a difference a new muffler makes :)
Guy who installed the muffler said my cats looked fine and the heat shields are tight.
There are still a couple of rattles I'd like to track down - but isn't there always...
Not trying to hi-jack the thread but I need to replace one of my cats.
I did a few searches and I got the impression if I went with aftermarket, I'll throw a code shortly after as the computer will think there's an issue.
Is this still the case? some of the threads I read were several years old.
Junr
[MENTION=78100]TRD 4RNR[/MENTION]
Why do you think it is the CAT?
Almost nothing in that thread says "hey it's the cats" maybe one post out of the 10.
1. Have you had your cats tested at a shop?
2. Are you throwing any codes?
I had a serious rattling sound and it turned out to be a leaking exhaust. My truck has 225k miles and my cats aren't "leaking" , I'm sure it's possible yours could be but I wouldn't assume so just because of the mileage.
A real cat is over $1000 each and the replacements work but are often inferior.
[MENTION=65101]BrianSD_42[/MENTION]
Hey Brian - Thanks for your comments - I updated this thread with a post a few days later - and you're right, my muffler was toast.
waterman2258
