California SMOG Help Needed - High NOX at 15mph
georgeecfc
Hi 4runners,
Need your help on passing my Smog...
Facts:
-1997 4Runner SRS Limited 4WD - Stock with 175k miles
-Engine was rebuit about 5k miles ago after radiator broke and it over heated.
- Since then check engine light was on for piston misfire but since was running fine and seemed like an issue with the sensor when they put it back together I was fine with it.... Until I took it for smog and it failed due to the engine not being in a ready state (the check engine light).
- It did pass the emissions part though with the below readings
15mph
RPM:1636
%CO2: 15
%O2: 0.1
HC: 35
CO%: 0.18
NO: 406
25mph
RPM:1585
%CO2: 15.2
%O2: 0.0
HC: 21
CO%: 0.06
NO: 183
- I took it back to the garage who did the engine rebuild and they fixed the check engine (it was 3 pistons reading as misfiring) by replacing the sensors and some other related parts.
- I drove it a couple of hundred miles to get the engine ready for the smog and then retested... This time it passed the Functional check but failed on the emissions.
15mph
RPM:1624
%CO2: 15.3
%O2: 0.2
HC: 15
CO%: 0.01
NO: 1276 - pass level 512 max
25mph
RPM:1615
%CO2: 15.2
%O2: 0.1
HC: 10
CO%: 0.01
NO: 324
The only difference between the operating conditions of the first and 2nd test was the first one I drove for 15 mins on the freeway immediately prior to the test for the 2nd there was a line so the truck was sat for over an hour cold before the test.
Do I need to fix anything before I do the retest or just make sure the engine is at operating temperature?
Thanks again!
George
Thanks again!
George
You should never shut off the engine while waiting for a smog check. Cold cats = poor performance. Ideally, you should take it for a drive, then pull into the test bay immediately. That's probably all you need to do.
-Charlie
mek
