Caliper clearance
backi00
I had a 2010 sr5 and really enjoyed it, but I felt I was still wanting more and after a lot of research and 6 months of searching I found exactly what I wanted.
I recently purchased a white 2006 sr5, v8 with 3rd row in unbelievable condition and 50k miles.
My question is: it seems the 06 sr5 is an odd beast in that it is supposed to still have the smaller calipers (12.×?), yet I've seen conflicting reports.
I'm under the impression that with the smaller calipers I can fit 16s as well as the stock 17 (265/65/17).
I'm trying to pick up a second set of wheels and i find great deals on tacoma take offs or fjs, but I want to make sure they will fit.
Any draw backs to running a 16 other than the speedo being off?
Thanks so much
You can definitely fit 16s with an 06 SR5 and, having done the larger (sport) caliper upgrade to my 03 SR5, I don't think you will notice any draw backs. The caliper upgrade, which limits you to 17" wheels, isn't enough upgrade in braking force to be noticed.
Thanks so much
Thanks so much! It's definitely going to make getting some winter tires for Cleveland winters easier.
I had previously run 16" steel wheels with snow tires on my '03 Limited here in Boston. I changed to 17" Sequoia wheels with snow tires. I didn't notice any difference in traction. What I did notice was that the steel wheels had a noticeably worse ride, which I suspect was due to increased unsprung weight.
Next time my '03 requires significant brake work, I will probably upgrade to 5th gen brakes, which will require 17" wheels.
H.Sikina
