firepawn said:The only reason that I went with the SRF was basically that a friend of mine had enough at his shop to do my truck, so it was free. He uses it in his track car and says it's the best, and will use nothing else. I agree about it being a little pricey to use all the time. If I was paying I prob. would have gone with dot 4. But the SRF really does work well, if you can swing it.
Koz said:There is no good reason to convert to DOT 5 (Silicon) unless you're racing. Even for racing, there are excellent DOT 4 fluids that have a 500+ degree boiling point. DOT 5 fluid can create many problems and MUST be changed frequently. Some systems are not silicon friendly. If you haven't converted yet, DON"T. If you have, don't convert back. You will have more problems. STAY AWAY FROM DOT 5 brake fluid, you will be sorry!
Koz
Casper said:the exact same reason that i dont normally push people to a 5. Since oh boy said that he already decided to got to SRF....looks like he is staying with it.
Brake seals dont like swapp'n back and for'th
firepawn said:Wow, didn't know dot 5 was such a heated issue! From what I can see the dot 5 works far better that my old stuff in terms of stopping the 20's. If it causes any problems, I haven't seen any.
Only thing is you have a change it more than normal, no big deal.
If it causes problems with rubber parts in the master etc. why would you use it in a high performance race car? My friend has 100's of thousands in his cars, the last thing he's going to do is put something in his cars that causes problems. A brake system is a brake system no matter how high permormance, or the application, all have rubber parts and seals. I agree with Casper and Koz that it is not really needed on a street car, dot 4 is fine. But I don't agree that it causes problems, it's just more expensive to use.
