Calling Limited fender flare experts
T4R2014
Elite Member
So for those with Limited or 2000+ wide flares, how does one remove the extension on the front bumper?
I got a 4Runner with this piece broken. If I find one at a wrecker I need to know how to pull it without breaking it. Thanks.
I believe there's a rivet located between the the fender flare and bumper flare that needs to be drilled.
Im missing that same piece on my bumper..any have a ljnk to a website i may be able to purchase from? If so please help a brother out
Sent from my SM-G950F using Tapatalk
The '97 Limited, '99 SR5, and '02 Limited I have taken off have all been the same- as far as attachment method. They attach with 3 or 4 studs/nuts. The studs at the top are secured to plastic brackets that rivet to the flare pieces, but there is no reason to remove the rivets [emoji1360]
Hi I have a 99 Limited. The lower part of the flare is part of the body flare correct?
Can it be masked off to paint it and would it look right?
What he said...
I just replaced one of mine,and I think you have to move the wheel well cove out of the way and feel for the bolts.My advise will be to spray some liquid wrench on them and let it sit for a bit.
I have both pieces- I could sell you one or both. They are simply bolted to the bumper and valance with 10mm head nuts.
Hey! I know this is almost a year old but did you ever end up selling those? The ‘99 Limited I just bought is missing them on both sides. Would gladly purchase off another member before eBay or hunting though junkyards.
MaximussK
