Camber?
88T4RE
hey guys! So I was under my truck today and I noticed this...it appears as though these two little circle thingies don't both point down? is this how you adjust the camber? the passenger one is way out of wack then? how do I adjust? any ideas?
Cheers!
P1000579.jpg~original
drivers side
P1000581.jpg~original
passenger side
P1000580.jpg~original
and they dont both need to be the same. I've aligned quite a few 4runners and have yet to see two line up perfectly. are noticing a pull when your driving? or smooth wear on one side of the tire? if not, your camber is fine. But if your concerned get your alignment checked.. no big deal
no it doesn't pull really that's why I thought it was kinda strange. It doesn't appear to have uneven wear on one side of the tire mind you the passenger tire has more wear than the driver side it's just not localized the whole passenger tire has more wear if you numsayin could be that the driver's was replaced I don't know I bought it this way. thanks for the response.
Cheers friend!
no problem! the best bet is to just get it checked on an alignment machine.. idk how much it costs though. i go to school at UTI so i have access to them
Ambrose67
