Camshaft sensor (po340) 1999 limited
olhobbler
I sprayed some lithium on some parts of the engine..engine light comes on, OBD says PO340 camshaft position sensor A circuit bank, 1 or single sensor.
Any diy advice on this matter would be appreciated. thanks
camshaft sensor update
Just thought I would full circle this post:
It wasn't related to the lithium spray..i had unplugged the camshaft sensor connection because it was loose from the plastic clip and possible could catch the belt. Maybe it needed time to discharge, because after sitting in the garage for a half hour or so, the check engine light immediately went off. No codes anymore. I am not as electrically oriented as some of you guys, but anyway, that's how this event ended.
