Can a OnX6 30 inch LED light bar run on a 4runner's stock alternator ?
Didzer
I'm asking because, on Baja design technical specs for the OnX6 the voltage requirements is 13.5 volts. On my 4runner the voltage fluctuates from the low 12 volts to a mid 13 volts. I was wondering if some king of voltage boost would be required to run the OnX6, or if the the 4runnerÂ’s alternator is good enough.
Thanx
Didzer
Thanx
Hi Didzer,
As you (Obviously) know, the Gen-5 4Runner is very light on Extra electrical power supply! I just posted a thread about raising the voltage (not to be confused with current availability), from your factory alternator, for a solid fully charged battery!
Raising the Alternator's voltage to properly feed your AGM Battery!
I don't know what the 30 inch LED-Bar (Maximum) power consumption rating is; most LED-Bars can be fairly efficient, which is their main selling point compared to the stock Halogen bulbs!
I did a tutorial thread about Alternators, and I think I calculated the factory 130A unit having about 20A to spare; "Nothing to write home about!" But if that's the only electrical mod you're planning for your 4R, you should be fine! Here's the Alternator thread that I did some time ago; your subject is a lil' different, but the electrical theory in this thread still does apply:
4Runner alternator upgrade (gen 5)
I'd double check the amp rating of the LED's that you're considering though, ...B-4... you buy the kit! Your alternator most likely is capable of 13.3v to 13.8v right now! With my mod, you'll Boost your voltage approximately 2/3'rds of a volt, which Should bring the system up to 13.9v to 14.4v!
Most of the LEDs that I've reviewed have an operating range of 9.5v to 17v; according to their spec sheets! But I guess that depends on the manufacturer, and how Honest that they wanna be, some companies post a "Wish-list" at best!
Check it out first and let us know what you find, and what you decide to do; you're not the only member here that has the same question(s)! 'Best to you',
rig, cheers!
Hi, rigtec
yep read your post, thanx. Might go that way and do the mod still need to do more research.
Didzer
AndiGarage
