Can fusible links be tested ?
Traveler74
I hate replacing parts at random until I finally locate a bad part. To say nothing of the expense. $$$$$
How do you test FUSIBLE LINKS with a multimeter ? are we looking for an open circuit (no continuity) OR for resistance ?
And are FUSIBLE LINKS in the T4R always located in engine compartment fuse box?
By fuseable link I'm assuming you mean an inline fuse.
Test for resistance from one side to the other with your Digital Volt Meter (DVM).
A good fuse should be short and near 0 (zero) ohms. You might not see exactly 0, but a few hundred mili-ohms is OK if you have a long run of wire in there.
A blown fuse is open and infinite resistance. It will be obvious.
Make sure you have your DVM set correctly to the lowest ohm scale and turn the car off.
I would say anything over 1 ohm is probably on it's way out.
Or to put it anther way, if your meter has continuity with the "beep" when you get a beep your fusible link is fine. If it's open or melted, its just like a blown fuse, no beep.
Sorry if i rubbed you wrong earlier.
This a 3rd gen?
You might get more help from asking in the generational related sections, 3rd gen section.
Did you see this...
Fusible link funk.
wwarren702
