Can i drive with this broken part?
Nape4
Hello guys
This part is broken in my car
attachment.php
I thought its called suspension but its too general
My broken part called strut?
And can i drive with this a little bit?
Thanks!!
can you explain what part is broken better or add a pic? 4runners dont have struts, they are shocks.
Thanks for answering me!
Yea so i think its the shock
Where i put the point its actually broke for two pieces
I would only drive slowly a short distance to a shop to get it fixed. Any more than that, like a commute, not a good idea.
The shock/spring is what is holding up the vehicle and if it pops out of that pocket when driving, the vehicle will compress a lot on that side and maybe bend some more parts.
If the shop that's going to fix it is around the corner, maybe.
With that shock eye broken off, there's nothing controlling that wheel. The end of the shock wedged in there is holding up the weight of the truck, yes. However, under cycling load, it could pop out and really f*ck some sh*t up.
If you're concerned about your safety and others around you, it would be wise to tow it to a shop and have it fixed.
It is definitely not safe to drive.
okay so please help me im very new in this cars options and i need help please advice me !!
i live in a small place 4-5 hours drive to the main city where i can find everything
i will need to order the suspension and put it together here with a local mechanic
because to tow the car will cost me 500$
option 1. to change front and rear -dobinsons 1300$ / oldman emu 1650$
option 2. to order some thailnd part its called profender
which will cost me 350$ only for the front
what should i do?
what should i do?
I would go with the second option, OEM spec should work fine for the street, you don't need the more expensive setup if it's for street use.
i live in very very bad roads area
everythings is holes and mountain roads
its kinda jungle
if i go with ild man emu
can you tell me whats parts i need to get in the kit?
of the old man emu?
because my mechanic told me that if i choose old man emu i will need to have another extra parts
its kinda jungle
of the old man emu?
Having been to Costa Rica myself, I would say to get that Dobinsons or OME stuff and lift it up a little because there's some fun stuff to do off-road!
When it comes to a lift kit like that it will come with everything you "need" depending on where you get it. Being front shocks/coil-overs and rear shocks with springs. It's recommended to get aftermarket upper control arms as well if you go with a lot of lift, so you can correct the alignment properly. Check your UCA/LCA bushings as well as ball joints while you're there so you may save some time later. No matter what you will at minimum need an alignment after.
Thanks a lot again!
Ahh i see, the upper control arms is what my mechanic told me i should get if i go with old man emu Suspesnsion.
Please help me get a decision what should i get:
1.old man emu nitrocharger sport kit 1650$ 3years gerente
2.dobinsons twintube nitrogas kit 1300$ 2years gerente
There is a big difference between those two that make old man emu worth more 350$?
charlesz
