What issues have you had with yours?I've heard tons of stories about how bulletproof they are, and no complaints... Until I got mine.
It might have just been installer error, but I've had mine in the shop twice since the install and I have a good friend who also had to have his torn apart twice.
That being said, they are still worth the money and effort if you're going to be doing some serious wheeling. A rear locker will get you through tough situations and make line choices a lot simpler. Having one on your DD is no problem at all as it's either fully on or fully off and is transparent when unlocked.
There are other options, like other brands, lsd's and swapping in an e-locker, that might be cheaper. Do some research (tons of discussions on this forum) to figure out which option is right for you.
I'm considering having a rear ARB locker installed. To those of you who are running them....are they worth it? Any regrets? Anyone runnig them on their DD? Any idea how durable they are? I will still be using my 4r as a DD for the next several years.
On the 5th gen we are more limited in options with the "8.2" diff
Umm, since you are in the 5th Gen part of the forum this info is wrong. For those without E Lockers ARB is the way to go, best bang for the buck, bulletproof if installed correctly and actually stronger than OEM which btw is way strong enough.
Aw, he's just grumpy cause he hasn't got a V8.Ummmm, sorry?
Wow, just trying to lend a hand - didn't realize about the 8.2, and like I said, swapping in an e-locker is an option.
Jeez, last time I venture into the 5th gen section again...
Ummmm, sorry?
Yikes, sorry. I was not trying to be mean but was just to correct misinformation.
Why?I've been wanting to replace my e-locker with an ARB.
I did some research recently because my general knowledge about lockers was pretty limited. Its still limited to only what I have read but most reviews were positive and having front and rear lockers was widely recommended, even for moderate off-road driving. Most of the negative info and reviews seemed to be attributed to the install done poorly. I already decided on a gear ratio upgrade (4.56) and am convinced that upgrading the front to an ARB air locker is a good idea at the same time. I am expecting my experiences to be very positive since it will make a huge difference being able to lock up the front and rear.
I will also say that Curtis and East Coast Gears have been very helpful and their customer service has been excellent thus far. However this will be a pretty costly mod in my opinion (right around 3k with parts, compressor, install and shipping the cores back).
Just my 2 cents worth...
