Can I run extended travel coilovers with oem UCA? I plan to add them soon...
BXPhoto
So guys, Im getting ready to order coilovers. Can I run the extended travel versions with oem upper control arms for a short period of time? I plan to buy the UCA as soon as budget allows. Looking at the Kings 2.5 extended travel setup.
Short answer: Yes
Long answer: Yes, just avoid full droop, because the knuckle will keep smacking the coils.
you can also Grind the knuckle a little and position the spring so it doesn't rub.
I did just that but still want to replace the UCA and LCA's later......its only $$$$ right
Laredotx
