can I unplug my Cold injector?
204runner
i have a 95 3l and after some playin around found out I have a bad cold injector After I start it and once i has warmed up can I unplug it and drive untill I come across another one? only plugging it in when needed? (when its cold) without running into any other problems?
Shouldn't cause any harm in doing that. I do that when I suspect that the CSI is running longer than it should, although I usually fix the problem shortly after.
The injector only does anything when the engine's cold. Unplugging it when it's warm isn't going to do anything for you.
its just there to help with cold starts unplugging it may make it harder to start your truck when its cold . why do you want to unplug it ?
I wanto unplug it cause when The engin is warm and I hut it off it seems to flood when re starting, making me believe its the cold inj running when not needed
workingwheelswnc
