Freeze Frame DTC: P050B
Fuel System Status: Closed loop, using oxygen sensor feedback to determine fuel mix
Calculated engine load value: 39.6078431372549 %
Engine coolant temperature: 51 ℃
Short term fuel % trim - Bank 1: -6.25 %
Long term fuel % trim - Bank 1: -0.78125 %
Short term fuel % trim - Bank 2: -4.6875 %
Long term fuel % trim - Bank 2: 2.34375 %
Engine RPM: 715 rpm
Vehicle speed: 0 km/h
Timing advance: 14 °
Intake air temperature: 16 ℃
MAF air flow rate: 6.43 g/sec
Throttle position: 18 %
Oxygen sensor 2 Bank 1 Voltage: 0.82 V
Oxygen sensor 2 Bank 1 Short term fuel trim: NaN %
Oxygen sensor 2 Bank 2 Voltage: 0.835 V
Oxygen sensor 2 Bank 2 Short term fuel trim: NaN %
Run time since egine start: 00:02:22
Oxygen sensor 1 Wide Range Equivalence ratio: 0
Oxygen sensor 1 Wide Range Voltage: 0 V
Oxygen sensor 5 Wide Range Equivalence ratio: 0
Oxygen sensor 5 Wide Range Voltage: 0 V
Commanded evaporative purge: 0 %
# warm-ups since codes cleared: 0
Distance traveled since codes cleared: 0 km
Barometric pressure: 0 kPa
Oxygen sensor 1 Wide Range Current (mA): 0 mA
Oxygen sensor 5 Wide Range Current (mA): 0 mA
Catalyst temperature Bank 1 Sensor 1: 0 ℃
Catalyst temperature Bank 2 Sensor 1: 0 ℃
Catalyst temperature Bank 1 Sensor 2: 0 ℃
Catalyst temperature Bank 2 Sensor 2: 0 ℃
Engine RPM: 715 rpm
