Hey guys, I'm also having an issue with the horn in my 2012 Limited, and I'm thinking it's the clock spring, here's the troubleshooting I've done:
-Checked horn fuse in K unit, is good. Swapped just in case, still no horn
-Pulled S-Horn relay and set off car alarm, horn honks, implies to me the horns themselves are fine, and the horn relay in the K unit is good.
-When I press the horn pad, nothing happens. No clicks no nothing. Implies the signal from the horn pad to the relay isn't getting there.
-I pulled the horn pad, and identified the two airbag wires and the horn wire. My understanding is the horn lead is connected to the whole back of the horn pad, and when you press the pad it touches the wheel which is grounded. This completes the circuit and triggers the horn relay. If I touch the wire to the steering wheel, nothing happens, and there's zero voltage from the wire to the column. I even unplugged the connector from the clockspring and checked voltage from the pin in the connector to the steering column, no voltage.
At this point I'm thinking it has to either be the clockspring or the connection from it to the relay in the fusebox, but I'm not sure how to find test points to verify continuity there, and honestly the clockspring seems WAY more likely than a static wire that's never been touched or moved in the last 8 years.
Thoughts?
EDIT: side note... do your horns work when the truck is totally off? Or do you need the ignition in the "on" position? I tried both ways but I just wanted to know for future testing.
