Cargo Area Window Leak?
aontkos
Hello all! I recently noticed that the front end of one of the windows in the cargo area is separated from the body, probably by a 1/4" or so. I figured that it was getting water in it somewhere, so I decided to investigate.
I pulled up the carpet and sure enough, on the side where the window is separated, there was a pretty significant amount of water. There was minimal rust (thank goodness), but the insulation under the carpet is pretty saturated.
Outside:
Inside:
Has anyone ran into this problem before? Does anyone know why just the top front corner of the would separate from the body? Also, should I look into taking my truck to a window shop for a repair, or is there something simply to remedy this?
idk why just the corner would leak, but all that's holding that window on is just glass silicon, sometimes they get loose. it's a easy fix, just go into window shops and have them reline the glass with fresh sealant
DJNutshell
