cargo cover brackets????
danny4runner
hello I need some help. I just bought a roll up cargo cover for my '07 4runner. It did not come with one and I guess I didn't realize that I need the 'Mounting Brackets' for the cover to latch into near the rear door. I figured the brackets would be behind the access covers..... but I was wrong. Does anyone know where I can find these in light gray.... or what they might cost? THANKS!!!
I added one to my T4R about a month ago. I just got the parts from a dealership, they weren't horribly expensive.
You will need to ask them for the tonneau cover hook, screw, and screw insert. It cost me about $50 for all of it. Almost all of that cost is for the tonneau cover hooks. They are about $22 ea. from what I remember. Screws and screw inserts are a few bucks a pair.
If you do order for them make sure that they order all three. When I ordered mine they said I only needed the hook and screw. Needless to say I had to go back and get them. The screw will not catch on anything if you do not have the insert to slide over the plastic behind where the tonneau hook goes for the screw to grab onto.
i added one to my t4r about a month ago. I just got the parts from a dealership, they weren't horribly expensive.
You will need to ask them for the tonneau cover hook, screw, and screw insert. It cost me about $50 for all of it. Almost all of that cost is for the tonneau cover hooks. They are about $22 ea. From what i remember. Screws and screw inserts are a few bucks a pair.
If you do order for them make sure that they order all three. When i ordered mine they said i only needed the hook and screw. Needless to say i had to go back and get them. The screw will not catch on anything if you do not have the insert to slide over the plastic behind where the tonneau hook goes for the screw to grab onto.
thank you very much for your help!
Got the hooks today from the dealer. Cost me $63 and they don't come with bolts. They threw those in for free. Fit great!
If I may ask, how much was the cover? My T4R came without it and I'm debating getting one or the other option is getting my rear and side windows tinted as I carry a lot of stuff. The tint will cost me $250.00. I don't want my things to become somebody else's treasure.
well from Toyota they are $630! lol They are on ebay used usually around $100-125. I got lucky and got one on ebay for $60! :dancin:I would tint as well if you don't have any thint at all.... but you should have factory tint right? 4Runners look silly with no tint
Ouch on the Toyota price. I've spent $450 on the cover for my wife's FX. I do have the factory tint, but planning on getting the darker tint over it and perhaps light tint in the front.
Check ebay out for sure if you really want a cover. a lot of people don't like them or just don't use it and would rather sell it for $100....
I think all 4th gens are tinted from the factory. I haven't seen one without tint. Only can recall base 2nd and 3rd gens without tint, typically the 4-cyl variant.
pretty old thread but i thought i'd check anyway.
would you guys have part numbers for the hook, screw and insert?
thanks!
Alright. I just ordered from Toyota Parts Cheap - Genuine OEM
1 Collision Catalog - 2006 - Toyota - 4 Runner
Quarter panel, Interior trim, Upper qtr trim, Hook Tonneau cover, Stone Right - W/o third seat - W/o third seat $0.00 $18.43
Quarter panel, Interior trim, Upper qtr trim, Hook Tonneau cover, Stone Left - W/o third seat - W/o third seat[/I]
also got 6mm x 20 bolts from Home Depot.
Toyota Parts Cheap.com
If the link above works I ordered part number 7 or 8 right and left side.
I know this is resurrecting an old thread but, there may be others looking for this info...
I purchased an 04 4Runner for my daughter, it has the third row seats but she needs the rear cover for her school stuff and sports equipment. Took the third row seats out and ordered the following parts to add the hooks for the cargo shade
Cover hooks: 64938-35030-B0 and 64946-35030-B0 (left and right)
Screws (2): 93240-56020
Screw spring nuts (2) (inserts): 90080-18062
Total was about 50.00 for all the pieces.
Hope this helps...
Bingo!!!
Hope this helps...
Thanks I have an 07 but this info definitely helps.
Toyotio
Thread res!
On Toyota Parts Deal I am having trouble discerning the color options - they are - "Stone" and "Fawn."
As far as I know the 4th gen interiors came in Stone and Taupe, so what on earth is "Fawn"? I have a taupe interior and am trying to find some part, and was curious if "Fawn" is actually taupe?
It is now 25 March 2026. You never know when someone will still need the information you posted long ago. Just letting you know I needed it. THANKS.
Here is an update. The parts that Toyotio listed were 100 percent correct. I ordered all 6 parts from the dealer versus ordering online. Yes, I could have a saved a few dollars, but in this case it was not worth the hassle. The left hook and right hook were only available in the STONE color, and they were $46.79 each. The 2 meta screws were $1.75 each. The 2 Screw spring Nuts were $4.43 each. The only difficult work was installing the 2 screw spring nuts. They were U shaped, and I had to slightly bend them open an additional 1 mm or so. Luckily, I have 2 other 4th gen 4runners as a guide. Be careful when installing them, because if you drop them, they will fall down behind the tail lights where you would likely need a magnet to retrieve them.
FYI. Since my 2007 4runner came with 3row seating, it never had a cargo / tonneau cover, so it had the plastic covers over where the tonneau cover fits on the right and left side, and it had plastic covers over where the hooks would normally be installed. If you have a 4th gen 4runner and want to delete / remove your tonneau cover and the hooks and make it look clean, below are the part numbers you will need. to cover the open holes Note that I suspect it would be difficult to get these 4 parts in the taupe / fawn color anymore. I know these part numbers are correct, because I pulled them off of my 2007 4runner, and I am reading the part numbers from inside of the plastic covers.
RH Tonneau cover plastic cover: 64935-35050 (outside shape is nearly square) (this covers the square left and right roles in the cargo area above the wheel wells)
LH 64936-35040
RH Tonneau Hook plastic cover 64938-35050 (outside shape is like a parallelogram) (this is the cover left and right holes at chest level at the very end of the 4runner near the rear window)
LH 64946-35050
