Cargo Drawer Build
cbelisle
Member
I've gotten some questions abut this, and I wanted to document the process, although I don't have pictures of most steps.
Started off with a base. Lots of cardboard templates. I used 3/4" ply.
Half of the area is for bike storage or other things such as a cooler.
This is what I got from version one. It was a basic drawer that worked. Nothing special. The drawer housing is good, but the drawer itself was a bit flimsy.
After using the version one setup for a while, I saw some places for improvement, especially after I saw my buddies setup with a pullout stove. So, back the the drawing board. I liked the base plate, and the cubby size, so it was just a matter of remaking the drawer. I also wanted a way to hold the stove.
Here you can see the new drawer. Pretty basic. I used 3/4" ply for the bottom, front, and back. The sides are 1/2" ply, with an additional piece of 1/4" ply laminated to the top half. The reason for this is to create enough room on the sides towards the bottom for the stove platform.
I got heavy duty slides that lock in both open and closed position. This is another thing I learned from version one when I parked on a hill. You can also see the stove platform sides, and why I needed the extra clearance.
Stove platform
Rivets to attach the slides to the platform
All mounted up
Mocking up the storage inside the drawer
And a top lid that acts as a counter-space for dinner prep
And lastly a couple spring loaded pins that lock the platform open and closed
And the finished product!
Very happy with the final product!
This setup looks familiar... are you friends with my buddy David Wang? Looks nice regardless and that is a nice looking workshop to be able to do fab work out of
Wow!! A+ for craftsmanship! Look Solid and Sick!! The functionality and purpose is phenomenal. :cheers: you're definitely and artist! :artist2:
DUDE. This is exactly what I need. I already built a base plate so this would be easy to add. Do you have the drawer dimensions anywhere? I have an ARB where your bike goes and I've been wanting to add a simple drawer on the passenger side that I can store my tools in and cook on. Great work!
Thanks! Yeah, I'm lucky enough to have access to my works shop every once and a while. Yup, David is a good buddy of mine, and we have very similar setups.
Thanks! I don't have exact dimensions in front of me, but it's basically half and half for drawer to cargo space. I used 32" slides for both the drawer and stove platform.
Couple of questions (Apologies. This is more or less exactly how I'm trying to build out my cargo area):
1) I think I did some measurements before and got 24"W x 40"L. That sound close to about right? Did you use Birch ply?
2) Where did you nab the slides from?
3) What are you using to secure it down? Can't see any tie downs
4) Any other pics of the sleeping platform?
1. Yeah, that sounds about right, and yes, I think it was birch.
2. I used these
3. There are 4 tie-down points in the factory cargo area w/ d-rings. I pulled those out and got longer bolts.
4. Here is the sleeping platform. It's a removable leaf that extends forward. in the front, it's supported by 1.5" dowels that go down to the floor.
The leaf has a lip that slides in and rests on top of the red piece of wood, and then is held secure by turnbuckles - so when tightened, it gets pulled into the back of the drawer box, making it very secure. I also have a platform that extends over to the other side so my wife and I can both sleep in there, but lately we've just been using a tent if it's the two of us so we have more space.
hope this helps
Sorry, should have been more clear. How are you securing the drawer to the plate? It looks like it is just resting in there. I did the same with my cargo plate and extended the bolts in all 4 corners. This was a mockup at the time, but fridge lives on driver side now.
Oh, it's just glued and screwed from the bottom. Makes it real fun trying to get out... but it fits, kind of.
Not that the price matters in current times but do you remember the total cost in this? This is exactly what i've been looking to do with bike storage and sleeping.
hey, I don't have an exact price but I'd guess around $300-$400. The locking drawer slides were the most expensive part - maybe $150. I used mid-priced plywood and then an order of aluminum and bolts/tee nuts from Mcmaster.
thanks. Did you (or anyone for that matter) remove the final carpeting/sound deadening layer or leave it in?
-I see in your IG you just got the superlite RTT? The shop isn't far from my summer job, was going to check it out and possibly pick one up. How do you like it?
I removed the padding under the carpet because it wasn't letting the platform sit flush. I added in some sound deadening material instead and put the carpet back on top.
Yeah, the tent is rad, highly recommend it! And they are a great company.
seltzernator
