Thank you in advance.
YES I used the search tool and couldn't find the exact answer I was looking for.
After installing all new OEM spec LCA's, new camber alignment bolts, and the EBay uniball UCA's, I brought my truck for alignment and I'm now getting a constant pull to the right. It's not from the crown of the road, definitely a stronger pull than I ever had from road crown, and my tires are all at the same PSI.
Have a 0.9 difference in caster from left (4.0) to right (3.1). Everything else looks good as far as I can tell.
QUESTIONS.....
1: Is the caster difference likely the culprit in my constant rightward pull?
2: How exactly is caster adjusted? The UCA's are non-adjustable
THANK YOU for your insight
QUESTIONS.....
