CEL code P0012
Pelley
I have been searching around here, google, and other forums and have not been able to find any feedback on the CEL code P0012. The CEL and VSC TRAC lights came on with this code. I had it read and re-set, waiting to see if it comes back on. But all the reader I used said was it was camshaft related... Any and all help and wisdom would be much appreciated! Thanks
Chris
Despite the age of this post, I Dealing with the same issue After replacing All the timing components in my 04 4Runner V6(1GRFE). So far, I have already Pulled the VVT-I solenoid and bench tested it with my multimeter as well as a 12 V battery pack to make sure the valve was opening and closing and it was, The resistance reading checked out. I have also checked the filter screen for the solenoid and it was clean.
So my next step now is to take off the valve cover And recheck the timing, which I know for a fact is correct After Triple checking everything before re-assembly.
I was doing some research on the cam Actuator itself , And From what I’ve read, there is a lock pin inside of the actuator that Can sometimes lock either in the Wrong position(Retarded or advanced) And if that happens, the VVT-I System will not function properly, causing a misfire and a check engine light. So that’s where I am at with this P0012 code and will update this post if I fix the issue!
