AF808fighter
Last couple days my truck won't shut off when I turn off the ignition and pull the key out, first few times I had to go backward against the starter, grinding it a little then the truck would turn off. After doing this 3-4 times the check engine light comes on and today at Advance Auto parts they ran the CEL and it came back "crank position sensor". I figured my issue was with the ignition switch which I'll be changing out tomorrow. What does the crank have to do with the whole situation? Is it throwing a code because I cranked against the running alternator/starter to shut the truck off? Truck is not over heating, and there is no popping sound or misfiring..its running smooth as ever. I am now just unplugging the MAF to shut down the engine per one of the members here, thanks for that tip btw.... 130,000 miles and this is the first real problem.
