CF 1" Spacer intall
Krazynative
Member
I just purchased a used CF spacer set for the rear and it didn't come with instructions. Before I install them is there anything I should be aware of? Does it go above or below the Spring?
- You're going to need a buddy.
- You're going to need a torque wrench, spring compressors, tie rod fork (although I was able to get my strut out/in without using this, although its a PITA). Ha, when I finished the job, I looked at the fork and was like, "WTH was I supposed to use that on?". A breaker bar would probably help too, some of those bas****s are TORQUED!
- http://www.toyota-4runner.org/showthread.php?s=&threadid=52008
That thread has the instructions in it, for the 2/1 though... try emailing Jason, He will get you the instructions I'm sure.
For the REAR ??
A little to nose high with the 2.5 ??
I think they may be talking about the front .
delislerebecca
