Changed the valve cover gasket today....
Spork520
on the left side, and during the time, I lost what I think is the dashpot cover? Its a little plastic cover with a small circular filter in it. I was driving to pep boys and my idle went all the way up and was stuck. I shut off my truck right away and pulled over. I started it again and it was normal, then I revved it up a little and the RPM's went up again. So I decided to drive it home on the 3rd time, I was right around the corner. I drove it normal and nothing happened, but it seems if the rpm's get a little high. Is what I am describing the dashpot, and would this cause it? I only changed the valve cover gasket and didnt have to take much off except throttle cable. Thanks
check your throttle cable.
check your throttle cable make sure the cable is hooked up correctly
ian2328
