Yes, I have about a wood block I cut from a 4"x4" in the compartment by the jack.
Even though the factory jack barely will raise the truck high enough to get the tire on, if you end up on the soft shoulder of the road and the ground is even a little soft you'd never get it changed without a block of wood or some other spacer.
Given the difficulty I have had just lowering the spare much less fooling with the factory jack it's AAA for me. For the life of me I cannot reliably get the shaft to mate up with the cable winch mechanism.
I've got 4 hydraulic jacks in the garage, 2 different designs...
for normal maintenance things.
Just curious, is the stock tire just barley able to fit on when using the stock jack. Looks like I'm going to have to use some wood blocks to get the tire on. WTF?
